A paper one, that is! Thought it would be fun to document my latest build as I make it; pretty much a DAR for modeling. Anyway, I'm using this build to get back into the swing of paper modeling. Due to that fact, I chose to make something somewhat easy; a submarine! I've always liked the LA class attack sub, so the choice was a no-brainer. Without further ado, let's begin (Pics are kind of crappy because I used my phone).
There are a total of 10 sheets that make up the model, and I printed them on 65 lb (175 g/m^2 for our European friends) cardstock. It's at 1/144 scale, so it'll be a good size model when finished.
I like to start by cutting out all of the supports and formers first. The hull formers for the sub are required by the instructions to be sturdier than just the thickness of cardstock, so I cut the formers out in groups and spray mounted them to a cut up cereal box. Final thickness was 1mm, so that will be plenty sturdy. Now comes the fun part, cutting them all out. The best way to cut out rings is to remove the center first and then cut around the outside. You have more to hold onto that way.
I have 15 of these to cut out, so I'll catch y'all on the flip side.
