U
Underfire
Patch has appeared over at BF
http://www.battlefront.com/index.php?option=com_versions&Itemid=317#CM
"This hotfix is for the download version of CMFI. It contains no new game code, but is a quick fix to the following small issues: - Fixed QB maps - Floating Icons fix - new optional shaders Instructions: 1) Download hotfix 2) unzip archive 3) you will find three folders inside the archive. You need to copy the files INSIDE the folders (not the folders themselves) as follows: (PC) open your My Documents/Battlefront/Combat Mission/Fortress Italy/Game Files folder. Copy the QB maps to the QB maps folder. Copy the contents of the Floating Icon Fix folder into the Mods folder. If you want to use the optional shaders, select the right shader for your video card (ATI or Nvidia), and copy the two files from that folder into your Mods folder, as well. 4) test the new shaders: Start the game and run a scenario. If the game is performing badly, or there are visual issues, quit the game and remove the shader files from your Mods directory."
