CMx1 Operations in the CMx2 Engine
Ithikial
FGM 2ND IN COMMAND
Staff member
Perth, Australia
(The following is a set of ramblings and ideas I’ve had after numerous rides to and from work on public transport. If I ever get a company car I will probably daydream, swerve off the road and die with my last words being recorded as ‘Pixeltrüppen headcount replenishment rates…')
I’m apparently part of a small breed of the CM community that misses the old CMx1 style operations.
For those younger CM Generals among us, CMx1 Operations were essentially one large map with an end objective to reach by the end of a set time period broken up into multiple engagements. Force Preservation and forward thinking were key to success. For example: “Okay, I’ve taken this village, do I keep pushing now while the enemy in front of me is disorganized or do I wait until sundown before creeping forward with additional forces that are due to arrive.” It wasn’t a perfect system by any means, for example there were issues regarding how the CMx1 titles calculated the deployment zones for follow up missions based on how far the player pushed forward. (It could be gamed a bit). The new CMx2 Campaign system is obviously more Designer controlled and is suited to following a more narrative structured event. My biggest gripe with the current system is depending on how the Designer builds the campaign and handles reinforcements/replenishment; it can heavily encourage players turning to a ‘save scum’ mentality, (a constant reloading of older saves when something goes wrong), knowing they are unlikely to achieve victory later on if they lose ‘x’ unit now.
Thing is I think we can create a CMx1 style Operation in the CMx2 engine. This is now largely possible due to:
- The far greater map sizes and units the engine can handle now compared to CMx2’s debut.
- The variety of forces now on offer in most titles once modules and packs are released.
- General beefiness of current computers.
So a CMx2 campaign is essentially a series of linked scenarios that form either one or two pathways to another (through 'winning' or 'losing' a preceding scenario). The thing is why do we always think of campaign progression as a ‘line’ and why not a ‘table.’ If the player ‘loses’ a scenario, let them try the same mission again with what forces they have on hand but push the time along a little bit for the follow engagement. Essentially:
- The player has one large map to clear.
- A player must hit numerous terrain based objectives in a set order to reach the final objective which ends the campaign.
- These terrain objectives are provided in an order set out by ‘higher command’ (the designer).
- If the player wins, they move on to the next objective in the next allotted time slot.
- If the player loses, they repeat the same scenario with time progressing to the next allotted time slot.
- As time progresses both sides receive reinforcements and replenishment though given the small time frames there would be at set periods or only in small increments.
- An extensive initial Campaign Briefing would be required.
- Briefings between missions would be minimal to represent the lack of orders from higher command during a prolonged engagement. Perhaps limited to some on the ground intel or feedback to the player on what type of support is coming in up in future engagements to help them make an informed decision around ‘commit now or later.’
- Forces on both sides would be essentially all Core Units and tracked for the duration of the fight.
The major limit to this approach is the fact that the CMx2 engine doesn’t support terrain damage carrying over between missions. The designer would have to be a little bit creative here and slow damage / rubble down the map as time progresses depending on the circumstances. Perhaps at a set point you damage key focus points on the map to take into account pre-planned bombardments from Army HQ assets.
Finally, what type of historical engagement would you be able to apply this to? One of my favourite CMx1 experiences was playing the Carentan Operation that came with CMBO. Yeah not exactly the most historically accurate, but it was a lot of fun slowly progressing towards the city with the 101st Airborne. If @WynnterGreen hasn’t disappeared fully (hint hint nudge nudge), we were doing some initial work on creating a ‘Master Map’ covering the area from St Come Du Mont down the causeway to also include Carentan itself. Gives you a sense of what the engine can actually do now in terms of map scale. If that map is ever completed I think it would be a prime candidate for some experimentation.
A rough early take on the structure of this scenario (note will have lots more potential engagements - only trying map out those that roughly close to the historical fight). The goal for the player is to get to the bottom of the table, but when this occurs is depends on how well the player proceeds. For example, they may get to the edge of Carentan, however they are two days late so it's already the 13th of June. This means elements of the 17th SS Panzer Grenandier have actually made it to Carentan to reinforce the beleaguered defenders.
Carentan%20Idea_zpsvkkc7isp.jpg~original
I’m really looking for thoughts and design considerations I may have missed regarding this pie in the sky idea. Oh and some hands up to help if there is any on offer. :p
i like your campaign concept, but the main obstacle concern on map damage and troops loss. Some thoughts:
- Destroyed group of houses (think as an enemy outpost) in the first 'battle 1' could magically reappear in 'battle 2'
- how you get rid of balancing of forces, battle 1 = 100, battle 2 = 80 and so on ?
If you need help on drawing maps and some sort of help drop me a line
I am with you in that group. I was very disappointed when I found out the operation system is gone. I made and played many ops in the CM1 series.
Going to read your post now...(edit)...done.
You have a good summary of how you would like it to unfold, but I think we are still coming up against the fundamental limitations of CM2 vs CM1.
Assuming the same map can be used over and over in a CM2 "Campaign", as Massimo points out, I'm not sure how we could preserve/maintain terrain damage and unit attrition from battle to battle?
This takes me back to the most ambitious CM1 project I undertook, and failed to see through to the end. :( This was a small tournament I designed over at We Band of Brothers, CMBB "Battle for Moscow".
Essentially, I designed a single map, and simulated an Operation by manually inserting and deploying reinforcements and reorganizing the front line based on each commanders intentions. It was a huge amount of work, and a classic case of biting off more than I could chew.
I see anyone trying to run a real old-school CM1 style operation, with the CM2 engine, coming up against obstacles that can only be overcome by a huge amount of "manual labour."
That is, unless you can figure out a way...and I would love to help you try!
How can I help? :)
In my campaign I use the same maps over and over if the same hex is attacked again. I add battlefield dammage, ruble, craters and destroyed vehicles (on the same spot as where they were destroyed). Yes this takes some time but the final effect is so much greater since it adds some more realism.
Has BF ever explained their reasoning for not implementing the same operation system in CM2 as found in CM1?
old CMx1 style operations. were very good , such a shame they were not carried on in CM2
