No idea.. this is my entire conversation with GreenasJade. He was very helpful.
The log file is saved in a place that depends on your operating system.
For me it is:
C:\Users\mgregory\AppData\Roaming\GreenAsJade\H2HHelper\h2hh_log.txt
You get told where this is at the top of the log window, but if you have no log
window that doesn't help
Another thing you can do is start h2hh.exe like this, from a dos prompt (or whatever on a Mac):
h2hh.exe reset-windows
This may help you get the log window back.
If that doesn't work, try
h2hh.exe reset-state
*But if you do try this, you will need to re-set up information about games in progress
when H2HH starts, so if you have some complicated setup (double drop box folders, or different folder names
to game names etc) you might not want to rush to try this measure.
You can use this link to send us more information
https://h2hh.fogbugz.com/default.asp?pg=pgEditBug&command=new
and Charles Texas Toast Reece and I will both see it. Or you can
send me an email
h2hh@gregories.net
Heaps of ways to get started figuring it out, hopefully we'll be sorted soon!
Martin
(GreenAsJade)
How do I start it via a dos prompt in windows 7.
The programme is on my desktop. Still cant find the log file.
I run through regedit and deleted all mention of H2HH and reinstalled. Still getting the Oops message.
Thanks
Shane
In Windows 7 you can get a dos prompt using windows-key-R then typing cmd (enter)
Then you need to change directory (cd) to where you have h2hh installed and type h2hh.exe
In Windows 7, the log file should be in basically the same place as I mentioned above:
... replace "mgregory" with your user name, that should be it.
Martin
Martin I did the reset state and it works a treat. Thankyou for your time.
Shane
