Need help with CMBN mod
Alpha Zwo
Germany
I have downloaded various US airborne uniform mods (e.g. ez US Airborne-Patched Uniforms_Normandy) but whatever I put into the Z folder they do not show in the game. Terrain and vehicle mods are working fine. Any idea how to make these work? Thanks in advance.
Two things for CMBN off the top of my head.
  1. Are you loading a mod tagged scenario that might ignore the uniform mods? This happens when tagged uniforms are loaded instead.
  2. Are the uniform mods the last such mod loaded? Loading sequence matters. If you load something else in the Z folder after that which contains those uniforms (especially a *.brz file), those uniform mods will be overlayed by the last file loaded. Consider putting the uniform mods into a "zzzzz" sub-folder so that they load last of all.
Thanks, mate. Not sure about the scenario, have to look into it. I have some files in sub-folders and other files (e.g. .brz-files) not in sub-folders. Will these files outside of sub-folders load last?
Loading sequence:
The folders inside CMBN/data/z/ are arranged alpha numerically and load in sequence from top to bottom. For example: effects, guns, terrain, uniforms, vehicles. Sub-folders within each of these are likewise arranged alphabetically.
Note, that a sub-folder within the folder 'guns' will load before any sub-folder within the folder 'uniforms'.
No matter how many layers of sub-folders there are within 'guns' these will always load before any folders within 'uniforms'.
As mentioned by Badger73, check for the presence of mod-tags both in the scenario (use the editor) and the mod and check the loading sequence. I would add to that the question, are your uniform mods the current 'smod_' type or the older non-'smod'? They should be the newer. Are they '.bmp' files?
If you are installing them as '.brz' you might need to unpack them to check.
Are you installing them using JSGME? If so, have you configured it properly to install the mods into CMBN/data/z and do they appear lower in the list than any other folder containing uniforms of the same name (replacing the latter is okay too)?
