Now here's something I haven't seen before...
A pace stick is a long stick usually carried by warrant officer and non-commissioned officer drill instructors in the British and Commonwealth armed forces as a symbol of authority and as an aid to military drill. A pace stick usually consists of two pieces of wood, hinged at the top, and tapering towards the bottom, very similar to large wooden drafting compasses used on school blackboards. They are usually shod and fitted with highly polished brass. They can open so that the tips separate at fixed distances, corresponding to various lengths of marching pace, such as "double march", "quick march", "step short", etc. When opened to the correct pace length, the pace stick can be held alongside the holder's body by the hinge, with one leg of the stick vertical to the ground, and the other leg pointing forward. By twirling the stick while marching, the stick can be made to "walk" alongside its holder at the proper pace. Otherwise, while on parade or when marching, it is normally carried tucked tightly under the left arm and parallel to the ground, with the left hand grasping the stick near the topThe pace stick is usually permitted to be carried off the parade ground by the regimental sergeant major alone; however, at a particular regiment's discretion, other sergeants and sergeant-majors or equivalent may carry a pace stick if they are qualified drill instructors. The origin of the pace stick is claimed by the Royal Regiment of Artillery, who used a "gunner's stick" to measure the distance between guns in the field. It appeared more like a walking stick, with an ivory or silver knob on the end, and, unlike the modern pace stick, could only be opened a fixed distance. It was quickly adopted and adapted by the Infantry as an aid to drill. #beingsingh Another stick carried by soldiers is the drill cane, regimental stick or swagger stick. This is a shorter cane, with polished metal ends. Sometimes these sticks are ornamented by a mock bullet casing, half at each end of the stick; these ornaments are often chromed, or left in their natural brass, but highly polished. They are carried on parade solely as an indicator of rank and authority by senior non-commissioned officers and warrant officers, and their use is generally governed (or restricted altogether) by the regimental sergeant major.
