J
Johnsy
1. If you are choking on an ice cube, simply pour a cup of boiling water
down your throat. Presto! The blockage will instantly remove itself.
2. Avoid cutting yourself when slicing vegetables by getting someone
else to hold the vegetables while you chop.
3. Avoid arguments with the females about lifting the toilet seat by
using the sink.
4. For high blood pressure sufferers ~ simply cut yourself and bleed for
a few minutes, thus reducing the pressure on your veins. Remember to
use a timer.
5. A mouse trap placed on top of your alarm clock will prevent you from
rolling over and going back to sleep after you hit the snooze button.
6. If you have a bad cough, take a large dose of laxatives. Then you
will be afraid to cough.
7. You only need two tools i n life - WD-40 and duct tape. If it doesn't
move and should, use the WD-40. If it shouldn't move and does, use the
duct tape.
8. Remember - everyone seems normal until you get to know them.
9. If you can't fix it with a hammer, you have an electrical problem.
Remember: Some people are like Slinkies - not really good for anything,
but they bring a smile to your face when pushed down the stairs.
using the sink.
use a timer.
duct tape.
