H
Herroberst
Will ongoing games be affected by loading the next module to CMBN? I have heard that it will but am double checking. What a drag to be sure.
A better solution is to have two parallel installs of CMBN, one at 1.01 without the module and a new one, 1.10, with the module. All you have to do is copy the whole folder of version 1.01 and rename it to someting like "CMBN old" before patching / updating to 1.10. You can then play both versions independently of each other and finish any outstanding PBEMs.
Yes Mad Mike has the right idea. There will be compatibility issue, so your best bet is to follow the about advice. I have two version on my computer. The one I use to play you lot of miscreants and the other one to do the beta testing of the commonwealth module.
Little update - change of exe file is working - but: pack of errors appeared for example: driver of my Panther has javelin as weapon , Truck driver is a "sniper: and many others....
