I've developed this quite simple fun campaign system for a fictional campaign similar to the Rico-Shorker Island War from last year that I played vs @Shorker and using the map design I developed for the fictional Borscht Island campaign for CMBS a few months back.
This one is returning to CM world war 2 ... either be played in BN, FI/GL or RT.
Looking for someone to playtest this with me.
Principle is following. All battles are played as QB's using a random map draw system.
Units are built by players using a production points system using strength points of three types:
Armour, Mech Infantry and Infantry
Artillery and Air support units are built separately.
Each side starts with 5000 points to build its army.
Each division can contain a maximum of 6 strength points of any combination (although it will move at the speed of its slowest component - ie: leg infantry)
each strength point costs the following:
Armour: 250 points
Mech Inf: 100
Infantry: 50
Artillery: 200
Air Support: 150
Each sides' cities & towns generate a total of 1000 points per turn to build new armies and pay for supply to maintain existing armies.
Each strength point represents points the player can spend in setting up the QB:
Armour: 750 QB points
Mech Inf: 750
Infantry: 500
Artillery: 500
Air Support: 500
So in example below... the Green 2. Tank Div is attacking the 5th Pz Division with support from the 1. Arty Regt
5th Panzer gets support from 2. Artillerie Abteilung and 2 points of Air Support.
So the QB would work out like this:
Allies - 3 Armour Points, 3 Mech Inf and 2 Artillery
This means they will be able to use for their OOB:
3x 750= 2250 points from the Armour Only
3x 750= 2250 points from Mech Infantry Only
2x 500= 1000 points from Artillery Only
Axis - 2 armour Points, 3 Mech Inf, 2 Artillery and 2 Air Support
2x 750= 1500 points from the Armour Only
2x 500= 1000 points from the Air Support section
A QB would be set up large enough to support all these points - but probably played out on medium to large maps with 30 to 40 minute battles maximum.
It would depend on players not cheating and being able to work out their OOB's well enough.
(the above looks like a LOT of points, but it doesn't actually buy that much kit)
Casualties on the CM battlefield would be transferred to the counters proportionally.
If you have 2 armour strength points, buy 6 tanks and lose 3, you will lose a strength point... same for infantry.
You would know what your opponent's theoretical strength would be, but FOW would be in that you have no idea your opponent will buy for a specific battle within parameters of the battle.
Advantage of this, there are no unit OOB's to keep track of.
There's quite a few details still to iron out ...
Like I said, it can be played in any of the WW2 CM formats ... RT is a little limiting due to limited number of QB maps ... with CMBN you'd like to avoid all the bocage maps ... I liked the feel and choice of maps in CMFI/GL...
Maybe @Shorker would be interested in having another go at something like this ... we can also play with a few players ... should be kept fun and light-hearted.
Armour: 250 points
Mech Inf: 100
Infantry: 50
Artillery: 200
Air Support: 150
Mech Inf: 750
Infantry: 500
Artillery: 500
Air Support: 500
