P
PoorOldSpike
You play a Cmbb May 42 QB 2000-points, 20+ turns, Meeting engagement mirror against me, swapping sides for the second game, then your percentage scores are added up and mine are subtracted.
The winner will be whoever beats me by the highest adjusted percentage and a hallowed inscribed cup will be sent to him (or a silver tankard if he prefers).
(EDIT- Winner Pauloondra chose a tankard)
As organiser, I can't win the trophy myself (sniffle)
All games count for the FGM ladder, the winner gets a sliver cup or tankard (his choice) and every competitor who finishes before the May 31st deadline will be awarded a Tourney cyber-Ribbon.
Russian T-34's whipped German armour in 1941, but can they defeat Hitler's new improved May 42 toys?
Buy whatever units you like, this is a guide to the main contenders-
The Germans at last have a 'proper' tank- the PzIVF2- which is quite capable of drilling T-34's and KV-1's frontally, but it's very expensive.
The cheaper Stug IIIF and Marder are also quite capable of dealing with T-34's and KV-1's but their lack of turrets is a handicap.
The PzIIIJ(late) has the best front armour of any of the German machines, and can't be easily penetrated by the T-34 and KV-1, but its 50mm gun has difficulty penetrating the Russians frontally unless at close range. It's sometimes issued with a few tungsten rounds which boost its killing power, especially against the slab-armoured KV's.
The T-34 and KV-1 can easily penetrate all German armour frontally except the PzIIIJ(late) which shrugs off most hits.
The big KV-2's 152mm HE-firing gun is inaccurate, slow to reload, but can damage or kill German tanks if it hits them or detonates on the ground next to them. Like the KV-1, it can be penetrated without too much trouble by the PzIVF2/StugIIIF/Marder, but the PzIIIJ(late) will have to get in close to hopefully penetrate frontally, although if it carries tungsten the job will be easier.
There is of course a much wider range of armour available to both sides which I haven't mentioned,so buy whatever you like.
The maps- Each one will be randomly generated by the computer for maximum realism and excitement, meaning none of us will be able to examine the ground until we deploy on the start line.
Therefore we must work out lines-of-sight and the best key terrain and avenues of approach etc 'on the job' without any prior rehearsal, just as in real life.
Below is a typical map to the same parameters we'll be using, namely Village/ Heavy trees/ Small hills/ Medium size map/ clear midday/extreme fow/Standard rarity-
The parameters will give a realistic balance of armour and infantry-
Typical 2000-points worth of forces to the above params. (Aircraft and artillery and anything else may be bought too).
Predictably the Germans are outnumbered (as happened historically), but Russian tanks have no radios at this early stage of the war and therefore have longer command delays, so it's a case of fast-reacting German quality against Russian quantity, historical again.
All in all, this May 42 period is one of the most balanced in cmbb because both sides armour is evenly matched and players must rely on pure skill to win.
Sign-up is open now, so send me your e-mail address, and i'll send the first files.
Also let me know if you want to finish the first game before starting the second, or whether you want to play both simultaneously.
The tourney ends MAY 31st 2010, that'll give us 6 weeks to play the two games which should be ample time.
If anybody's late seeing this thread and wants to sign up, no problem,you can sign up whenever you like before May 31st as long as you think you can finish the two games before that date.
SIGNED UP SO FAR
Sign up and I'll edit you into this list
Bootie
Airborne Bob
Ratzki
Bert Blitzkrieg
95 Bravo
Wardog
Cargol
Von Reich
Johnsy
Changed
Mikey
Andre
Lord Bane
Nort
Owl
Pauloondra
Rico
Seel
Eniced73
mgk
AntiG3n
Gunner
LRC
